Park assistant
- hammerg
Park assistant
Hello, I own a 2014 Grand C4 Picasso (2.0 e-HDi, automatic transmission, Exclusive trim). Everything works except for the automatic parking feature. I have the Park Assist button and can select the parking mode on the screen, but nothing happens after I make the selection; the spinning icon that should appear is missing. I’ve noticed that the only response is an audible beep when a gap between cars is detected. My question is: did this model year actually feature full automatic parking, or was it limited to just an audible alert for a gap? I have Diagbox 9.85, and when checking the AAS module, I see that "semi-automatic parking" is selected. That is the extent of my knowledge regarding where to check or adjust settings to get the function working so the car steers itself. Could you please advise on exactly where I should check and configure this feature?
- Boblebricolo
Re: Park assistant
En Français c'est mieux.hammerg a écrit : jeu. sept. 17, 2026 5:21 pm Hello, I own a 2014 Grand C4 Picasso (2.0 e-HDi, automatic transmission, Exclusive trim). Everything works except for the automatic parking feature. I have the Park Assist button and can select the parking mode on the screen, but nothing happens after I make the selection; the spinning icon that should appear is missing. I’ve noticed that the only response is an audible beep when a gap between cars is detected. My question is: did this model year actually feature full automatic parking, or was it limited to just an audible alert for a gap? I have Diagbox 9.85, and when checking the AAS module, I see that "semi-automatic parking" is selected. That is the extent of my knowledge regarding where to check or adjust settings to get the function working so the car steers itself. Could you please advise on exactly where I should check and configure this feature?
Faites un effort ici c'est un forum Francophone.
- hammerg
Re: Park assistant
Je suis désolé, mais je ne viens pas de France et il m'est plus facile d'écrire en anglais..Bonjour, je possède un Grand C4 Picasso de 2014 (moteur 2.0 e-HDi, boîte automatique, finition Exclusive). Tout fonctionne, sauf le système de stationnement automatique. Je dispose du bouton « Park Assist » et je peux sélectionner le mode de stationnement sur l'écran, mais rien ne se passe après cette sélection ; l'icône animée qui devrait apparaître ne s'affiche pas. J'ai remarqué que la seule réaction du système est un signal sonore lorsqu'un espace entre deux véhicules est détecté. Ma question est la suivante : ce modèle disposait-il réellement d'une fonction de stationnement entièrement automatique, ou était-il limité à une simple alerte sonore signalant un emplacement disponible ? Je possède Diagbox 9.85 et, en consultant le module AAS, je vois que l'option « stationnement semi-automatique » est sélectionnée. C'est tout ce que je sais concernant les réglages à vérifier ou à modifier pour activer la fonction de braquage automatique. Pourriez-vous m'indiquer précisément où vérifier et configurer cette fonctionnalité ?
Re: Park assistant
hammerg a écrit : jeu. sept. 17, 2026 7:08 pm Je suis désolé, mais je ne viens pas de France et il m'est plus facile d'écrire en anglais..Bonjour, je possède un Grand C4 Picasso de 2014 (moteur 2.0 e-HDi, boîte automatique, finition Exclusive). Tout fonctionne, sauf le système de stationnement automatique. Je dispose du bouton « Park Assist » et je peux sélectionner le mode de stationnement sur l'écran, mais rien ne se passe après cette sélection ; l'icône animée qui devrait apparaître ne s'affiche pas. J'ai remarqué que la seule réaction du système est un signal sonore lorsqu'un espace entre deux véhicules est détecté. Ma question est la suivante : ce modèle disposait-il réellement d'une fonction de stationnement entièrement automatique, ou était-il limité à une simple alerte sonore signalant un emplacement disponible ? Je possède Diagbox 9.85 et, en consultant le module AAS, je vois que l'option « stationnement semi-automatique » est sélectionnée. C'est tout ce que je sais concernant les réglages à vérifier ou à modifier pour activer la fonction de braquage automatique. Pourriez-vous m'indiquer précisément où vérifier et configurer cette fonctionnalité ?
Pour être sur que cette fonction est bien présente sur votre véhicule vous allez chez un concessionnaire ou agent Citroën avec le certificat d'immatriculation ou figure le N° de série de votre véhicule il seront en mesure de vous renseigner.
Dans votre texte je lis que vous faites référence au bouton Park Assist, j'en conclu que cette fonction est probablement présente...
1°) votre véhicule est-il équipé d'un attelage?
2°) vous avez Diag Box, faire une lecture des défauts dans le BSI
Lorsque avec le bouton Park Assist vous activez cette fonction un pictogramme vert devrait apparaitre.
Il faut vérifier physiquement les capteurs avant et arrière et le faisceau câblage et les prises
- hammerg
Re: Park assistant
Merci pour votre réponse. J’ai Diagbox et je n’ai aucune erreur dans les modules BSI et AAS. Les capteurs de stationnement avant et arrière fonctionnent tous correctement, oui, j’ai un attelage de remorquage. J’ai le bouton sur le volant comme sur la photo. Lorsque j’appuie dessus, le choix du mode de stationnement apparaît sur l’écran inférieur, le pictogramme vert s’allume, mais sur l’écran supérieur devrait apparaître la voiture avec l’icône tournante. Chez moi, cela n’apparaît pas. Je comprends que les voitures diffèrent selon l’année de production et l’équipement, mais je voudrais savoir si, dans mon cas, cette fonction peut être limitée à cause de mauvaises réparations effectuées par le précédent propriétaire. Mon VIN est : VF73AAHXTEJ788720.
Re: Park assistant
vous trouverez dans vos MP le descriptif complet de votre véhicule provenant du constructeur.
J'ai relevé ceci qui pourrait correspondre à parck assist (DÉTECTION D’OBSTACLE DETECTEUR OBSTACLE RADAR AV AR +
CAMERA AR+PK AUTO)
Combien de capteurs ultrasons y a t-il sur le pare chocs avant et arrière.???
Surtout comment sont-ils précisément disposés sur le pare-chocs????
Combien a de Kms ce véhicule???
Pour l'attelage quand une remorque est accrochée au véhicule dans la prise de l'attelage il y a un contact qui désactive l'utilisation du parck assist, avec la corrosion ce contact peut rester en position de désactivation ou simplement modifié par l'ancien propriétaire pour neutralisé le parck assit, peut être une piste...
En principe en France cet équipement devait être présent de série approximativement vers 2013 sur la finition Exclusive...
- hammerg
Re: Park assistant
Merci pour le fichier avec les données de la voiture. Le capteur pour l’attelage fonctionne bien. J’ai vérifié parce que j’ai une remorque et quand je la connecte, certaines fonctions changent. J’ai 6 capteurs dans le pare-chocs avant, 6 à l’arrière, caméra avant, caméra arrière, caméras dans les rétroviseurs extérieurs. Maintenant, j’ai vérifié et une caméra gauche dans le rétroviseur ne fonctionne pas, mais même quand toutes fonctionnaient, j’avais un problème avec l’assistant de stationnement. Le véhicule a maintenant 200 000 km. J’ai vérifié exactement les erreurs dans Diagbox et il s’avère qu’il y a une erreur de communication dans le module d’assistance de direction avec l’AAS.
Dans quelques jours, je vais essayer de réparer la caméra dans le rétroviseur et je vérifierai si quelque chose a changé. Si je comprends bien, le BSI doit communiquer avec les modules de l'assistance à la direction, ABS/ESP, moteur, AAS, capteurs de stationnement et caméras.
Re: Park assistant
hammerg a écrit : lun. sept. 21, 2026 4:25 pm Merci pour le fichier avec les données de la voiture. Le capteur pour l’attelage fonctionne bien. J’ai vérifié parce que j’ai une remorque et quand je la connecte, certaines fonctions changent. J’ai 6 capteurs dans le pare-chocs avant, 6 à l’arrière, caméra avant, caméra arrière, caméras dans les rétroviseurs extérieurs. Maintenant, j’ai vérifié et une caméra gauche dans le rétroviseur ne fonctionne pas, mais même quand toutes fonctionnaient, j’avais un problème avec l’assistant de stationnement. Le véhicule a maintenant 200 000 km. J’ai vérifié exactement les erreurs dans Diagbox et il s’avère qu’il y a une erreur de communication dans le module d’assistance de direction avec l’AAS.
Merci pour le retour
Bonne continuation dans la recherche du problème.
